Can anyone tell me what this is
Irishspring46
109
35
I think it’s an 8.5 10 bolt I was told it is a grand national rear end??
Rktpwrd
Builder of Cool Shjt
4,181
23,998
Calgary, Alberta, Canada
Irishspring46
109
35
That is indeed an 8.5” 10 bolt rear end. The squared off triangles at the bottom are the dead giveaway, 7.5” rears have what look like curved “fangs” there. It could be GN, but it could also be from an Olds 442.
Thanks these came with 342 gears and 373?
Rktpwrd
4,181
23,998
Correct. Not all came with the G80 PosiTraction option though, so be aware of that if making a decision on it. Do your due diligence.
8,259
17,785
3.42 came in the GNs.
3.73 came in the 84 H/O and 85-87 442s. (83 H/Os had 3.73 but had a 7.5.)
Of course, you could swap them out to whatever gear ratio you wanted.
GP403
Administrator
Site Admin
Feb 25, 2005
4,515
4,938
Rolla, MO
Thanks to those who took the time to help the OP out. I would eat off of that rear end. :wtf:
Quick aside: Do you know *why* "Google is your friend?" Because of people helpfully answering questions and sharing experience and information on the internet. 🤔 It's true.
Carry on!
ssn696
Living in the Past
5,552
6,700
Permanent Temporary
If the hen's tooth you find is a non-posi, that's a bargaining point, and you can upgrade to a 30-spline 8.5/8.6 GM truck differential and upgraded Moser GN axles to match.
Reactions: 7 users
Ribbedroof
4,930
7,073
Wellston, OK
Devil's advocate time
It does in fact appear to be an 8.5 rear center section
The 8.5 rear was used in a lot of applications over the years. There have been a few that were swapped into G bodies from other vehicles. Some done well, some not. None would be a direct swap, aside from the aformentioned G body models.
I would ensure that it is the correct housing before I would start negotiating on it. Chances are it's the real deal, but you need to go into it eyes open
Irishspring46
109
35
How would you determine if it was done well or not? Just by how it functions/rides?
