Another Prototype Gasket in the (it's already here) Edition- Can't Believe They Haven't Repro'd This One
69hurstolds
8,259
17,785
At least I can't find any evidence of them repro-ing it. It's a little different than the earlier A-body versions. The slice is in a different spot, as well as the size. Seen them on ebay for almost 20 bucks plus tax...EACH! No friggin' way. I think I can make a repro that works.
Trunk lock retainer gasket GM p/n 1718294. Fits various A-bodies, G-bodies, B-bodies, C-bodies, E-bodies, etc. 78-88. Yeah, probably some of you didn't even realize there was a gasket back there. :)
The GM gasket is actually made of a dense, closed-cell, neoprene foam. My prototypes are made from what I had on hand, which is some EDPM sheet rubber. My point was seeing if it could be cut and work. And yes, it can and does. I have the correct material on order now so we'll see how this goes in about a week when I get it. Design and cut plots are finalized and ready. Now I just need the right material. Plotter is set up for 65 gaskets to cut in one shot. All ready to go.
Need to find out, too, if the brake booster gasket is the same foam rubber stuff (GM p/n 9791640)...there are repros out there, but the shipping on them KILLS the deal. Try and get a $5 booster gasket and not pay 10-15 in shipping from these places selling them. Yikes. I know I can do it cheaper. May not make a slew of them, but just being able to make a cut program for it and do it when I need to is worth it. I only have 3 NOS ones of those on hand, so I may not ever really need them, but y'all redoing your G-bodies might like to have one or two. Why pay $20?
The trunk lock retainer I'm using and showing here is GM p/n 20223910. It's for a G47 Olds, 81-88, but the point is, the retainer mounts to the trunklid with a single rivet. (retainer is p/n 20014418 for 78-80 A47 but uses the same gasket)
Repro prototype made of EPDM rubber sheet. Original GM is made of thin, neoprene closed-cell foam.
Repro-
How it mounts-
  • Winner
Reactions: 9 users
69hurstolds
8,259
17,785
I recently took all my locks out. My trunk lock retainer had no gasket at all. I wonder if it was a "who cares" on the assembly line.
Hutch
Never... Are you saying they didn't have 100% success rate on QC checks? :)
Reactions: 7 users
69hurstolds
8,259
17,785
I've pulled a ton of those retainers from trunk lids and not one had that gasket lol
See what I mean? A lot of people don't even know it's supposed to be there. I'll go check the 85 and 87, maybe tomorrow. They should have one if it's not disintegrated away already. They've never been removed.
84 W40
582
795
Just for curiosity I went to check to see if that gasket was there on the Hurst. Yup it was there
88hurstolds
1,754
669
This seems like the same scenario with the air cleaner wingnut grommets...
69hurstolds
8,259
17,785
Finally got 'round to checking the 85 and 87. Yup. I know the 84 has one because I distinctly remember putting it in there. Thought it was stupid, but whatever.
85
87
Lord how dirty it is up in there. Gak. But they're both there. They're both a bit crispy, but still hangin' in there. Obviously they'll get replaced one of these days.
