MALIBU TH 400 noise
pontiac guy
582
843
Royse City, TX
Considering I saw a picture of a member getting ready to install an engine with the converter already bolted to the flexplate without the trans I have to ask are you sure the converter was seated all of the way on the pump?
First car I ever built. 79 Cutlass 400 Pontiac TH 400. I did that very thing. Used to bolts to pull it together. Took both lugs off the pump. I learned everything the hard way. Sooo...
I agree, it sounds like the pump on the trans. This may be waaaaay into left field and obvious but are you getting RFI interference thru the radio? Don't scoff, it's happens. Easier to fix than a pump too so...
565bbchevy
9,633
12,760
Michigan
IMO if someone can't pinpoint the noise of RFI or a blower motor then maybe they are in the wrong hobby.
pontiac guy
582
843
Royse City, TX
I assume every learns the hard way like me, and doesn't have a lot of experience. Another example (not to hijack), same car 2 months after I replace the pump in the trans. I get in the car to go out and do what 18 year olds do when their mommy isn't looking. I start it up, and it's out of the blue knocking. Motor is barely broke in. My spirits are completely broken. I call my friend tell him what's up and go into my room to cry like a sissy who just got slapped. My friend zooms over climbs under the car in the street and find that all the effing converter bolts had come loose. Damn thing is flopping around. My dumb *ss doesn't know any better and assumed it's a rod knock. I never trusted the locking feature on those bolts again. Loctite every stinking time. Again I learned the hard way.
Most people learn from You tube these days. There is almost no good info out there. You should hear some of the things I get asked by the kids at work. They saw it on YouTube so it's gotta be true. So basically I'd rather look stupid and offer up radio noise than have a new guy get his hopes crushed right away. But I agree, I would hope that things like radio noise were already discarded
565bbchevy
9,633
12,760
Michigan
I bought a car for $75 years ago with that issue, it had a recent trans install and eventually developed what they thought was a rod knock, the new torque converter bolts where too long and bottomed out, I did sound a lot like a rod knock but to me it was more external so I bought it.
Ratchet
251
97
The noise is definitely not radio or blower motor. One person that heard it asked if the car had a gear drive. I’m taking it to the transmission shop that rebuilt the TH400 in on Tuesday.
565bbchevy
9,633
12,760
Michigan
So does it sound like it is coming from the timing cover area?
565bbchevy
9,633
12,760
Michigan
He built the motor he should know if it has a gear drive or not I hope
Assuming he has a chain I was thinking a possible alignment issue causing a gear noise sound.
Ratchet
251
97
It has a tradition timing chain with a Holley (cast aluminum) timing cover. The noise sounds like it’s coming from the back of the engine. However, I’m not going to rule out the the timing cover just yet.
