grounding your radiator
Built6spdMCSS
5,839
9,766
Florida Beach
Supercharged111
4,943
7,740
Colorado Springs, CO
Also make sure you Dyno that puppy when it's all said and done.
Sweet_Johnny
Has A Face For Radio
699
1,261
Wichita, Kansas
This is what was taught to me: When liquids flow through dissimilar metals it causes electrolysis. This is because the friction created by the fluid rubbing against the metal causes a slight electrical charge, and different metals produce different amounts. The charge seeks an outlet or at the very least electrical equality, so it flows just like a traditional electrical signal. The aluminum is the weakest metal in the equation so it gives out first, but adding a sacrificial zinc anode solves the problem. Adding a ground should help.
86 Salon
Mar 14, 2021
72
80
can you post a picture of your install
I put one of those in my Griffin radiator for my 73 Buick. The radiator had a threaded hole for a heater hose fitting in the top of the right tank. I just put a reducer bushing in the hole so the anode would fit. It's been in 8 years and I would say that it's about 10% gone so it must be working. Good insurance.
86 Salon
Mar 14, 2021
72
80
Here's a picture.
84cutspreme
1,147
152
Here's a picture.
I put mine in place of drain. On Becool radiator it is on pass side bottom of tank. Wondering if it will hinder flow on outlet or deteriorate faster because it is in direct flow? 🤔
