87 Monte SS build
T-TOP TONY
479
410
san bernardino, ca
Tony,
Did you get this figured out? How to tell the difference between a PV4 and a PV2?
Dave
No sir, never did I'm just going to keep it, and if they lock up once they're installed, then I'll know it's the proportioning valve.
T-TOP TONY
479
410
san bernardino, ca
Rear brakes arrived 😎
T-TOP TONY
479
410
san bernardino, ca
Added all the front brake lines today, a long with new clips and bolts from inline tube. Also mocked up the Wilwood flexline. PXL_20240515_223301848.MP.jpg PXL_20240516_001553006.jpg PXL_20240516_000246962.jpg
Reactions: 7 users
T-TOP TONY
479
410
san bernardino, ca
Had to get a new hoodie made with my logo.
T-TOP TONY
479
410
san bernardino, ca
I had been dodging this broken bolt, since I took off all the other body mount bolts. Well today I decided to tackle it. Sprayed the hell out of it for 3 straight with PB blaster. Used a stud extractor socket and turned it slowly by hand, and managed to take it out. The threads on the part that the bolt screws on to, look a bit messed up, I'm going to try to clean em up with a m10x1.5 tap. Hopefully that'll do it. If not I either go a size up or I'm going to have to replace it.
Sweet_Johnny
Has A Face For Radio
797
1,481
Wichita, Kansas
I've never tried it for this application but would a Heli-Coil work?
T-TOP TONY
479
410
san bernardino, ca
Great question. I honestly believe I could have gone 305 which is 10mm or 4/10ths of an inch larger. I can put my finger between tire and frame and between tire and fenders. Let's say my finger is half an inch. Even with 3/8ths that would give me 3/4 an inch total space. Not enough for a 315. 305 max for me.
That might be an option as well.
Sweet_Johnny
797
1,481
Wichita, Kansas
Spectacular build btw- I just got all caught up and everything is very clean, organized, and well thought out. I'm a bit jealous.
T-TOP TONY
479
410
san bernardino, ca
Thank you very much brotha. I wish I would've been done a long time ago. But with kids, work and school, I only work on it, when time permits it. Hopefully by the end of the year I'll have it running at least.
