GBodyForum Supporting Vendor
Transmission Cooler lines?
User avatar
ZZ4CutlaSS
G Body Guru
Postby ZZ4CutlaSS on Fri Mar 16, 2012 9:42 pm
Need help with buying cooler lines for my trans. It's a 2004r trans bolted up to a sbc. I plan on running a secondary cooler in front of the radiator also. Is there a kit available with lines I can make or what other options do I have?
1984 Oldsmobile Cutlass Supreme. Powered by a AFR Headed ZZ4, Hot Cam, TH350 2,500 stall, 8.5 with 3.42 gears. Image
thedoctorisin
G Body Guru
Re: Transmission Cooler lines?
Postby thedoctorisin on Sat Mar 17, 2012 2:56 pm
Check out summit racing, they have braided line kits for less than 100$.
From what I understand, the lines are relatively low pressure and you could use rubber lines with barbed fittings on the trans and cooler.
1979 Olds Cutlass. Tuned LT1, 1.6 rocker arms. TH350 . Locked 7.5 rear.
1994 Lincoln Town Car, 100% stock.
1999 Jeep Cherokee, 4.0, 4X4. Stock for now.
Free Shipping on Orders Over $75!
User avatar
ZZ4CutlaSS
G Body Guru
Postby ZZ4CutlaSS on Sat Mar 24, 2012 10:37 pm
I ordered some parker rubber hose and fittings from work which ended up costing $28 and some change. Not bad for good quality hose and fittings. I also went to my local parts store and picked up some heat sheathing and P-clamps to protect them from the heat from the headers. I will update with some pics later.
http://www.parker.com/portal/site/PARKE ... a71dacRCRD
Return to Oldsmobile Cutlass / 442 / Hurst/Olds
Who is online
Users browsing this forum: No registered users
