Replacement rubber inserts for side molding
2
I am looking for a source for the rubber inserts that fit into the riveted protective side moldings for my 87 Cutlass. The ones I have are deteriorating and are hard to keep looking presentable. The chrome rails are in great shape. The inserts I have are light blue in color. Any thoughts?
88hurstolds
1,749
659
They are not factory moldings so finding a replacement to an aftermarket part is going be difficult since they're one off...
If it were me I would remove them if possible and replace them with aftermarket adhesive ones to look more like the factory since there is really no way to fix the issue with inserts that I am aware of and you have to deal with rivet holes.
My suggestion is a Google search... you might be able to find some sort of vinyl trim that can act as an insert.
The aftermarkets are 5/8" wide vs. the factory 3/4", not sure if you can still find them though... I know aftermarket black was available a few months ago with a texture to it but colors were discontinued a few years ago.
Stuff for these cars is slowly disappearing, www.rockauto.com is slowly drying up with replacement parts for these cars, I get closeout emails once a month.
Sucks...
One thing I do have is light blue vinyl side molding, it's about 1 1/4" wide but you might be able to fashion it somehow...
May 21, 2014
2
Thanks for the reply. I've tried quite a number of Google searches to no avail, so far. I understand that the moldings are not factory but they are installed over a factory paint job that still looks great. I want to avoid adhesive strips if possible, hence my post on this venue. Still looking for a source.....
