86 olds 307 to 74 olds 350
chiefballer52
13
My question is, will the exhaust manifold from the 86 manifolds cause too much back pressure, and cause damage to the motor.
I know they will bolt up, and work, and I know most would not do it as it will restrict massive power instead of headers, but I'm in a tight budget, and need to get my car running as it's difficult to get to three jobs without the car.
But will it cause any other negative effects detrimental to the stability of the motor?
It currently is set up for true dual all the way back. If that matters..
bigblockfrank
208
4
mt.vernon, ky
350 stock? if so carry on with the 307 exhaust.
chiefballer52
13
It's a rebuild,
Comp cam n timing
Milled heads #8 heads
7111 edelbrock intake
650 cfm edelbrock carb
Oct 14, 2008
8,823
7,775
Melville,Saskatchewan
Use them for now but get early 307 manifolds as soon as possible. You will notice a performance gain even with the tiny tubular manifolds over the swirl port turd 307.
chiefballer52
13
I actually have headers that came with the motor, but I've already gone fat over my budget, and can't afford the modifications to make these fit.
I will be putting them in, in the next month or so though.
Oct 14, 2008
8,823
7,775
You will be fine till then.
