Hey Guys,
I may have made a big $$$$ mistake and would like some expert advise
before going to the smog referee. I should have researched first before doing the
engine swap cause I'm not real clear on the Calif smog law which
is kinda vague.
My question will I ever be able to pass the Caif Emissions test with this engine
swap.
2005 1500, Silverado 5.3L and 4L60e trans combo into a 1985 El Camino SS.
The new motor has a LS1 stock intake manifold, and front water pump group,
a/c, p/s, alt and pulley from a 04 GTO 5.7. Exhaust are 04 GTO with inboard and
outboard 02's and cats. Oh the block is iron.
The way I read the law is that you can swap a light duty truck engine 6000GVW,
or under into a car. Well I found out that the silverado is 6100GVW. So am I sunk?
But my thinking is that a El Camino is a truck. Because it is rated a 1/2ton,
it has a bed and the DMV requires I have Commercial plates and charges me
so. So shouldn't be light truck to light truck, right?.
I don't want to throw anymore money at it if I can never get it smogged.
Your help will be appericated........
Thanks,
Joe
is kinda vague.
swap.
Thanks,
Joe
