The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
Get the GBodyForum e-mail newsletter!, Contests, Events, Deals, Forum News and More!
It appears you're not logged in! Not a member? Registration's FREE and only takes a minute!
Register now or Log in to hide this ad block.
GBodyForum Supporting Vendor
removing body from frame
Stuff like brakes, frame, springs/shocks, tranny's, etc. etc.
User avatar
malibootay
Postby malibootay on Thu Feb 06, 2014 10:28 am
How hard is it to take the body off the frame of my 81 malibu? what all is involved? what all do i need? I dont have a lift and would be doing it in my garage
rodneypierce
Re: removing body from frame
Postby rodneypierce on Thu Feb 06, 2014 12:41 pm
following, as I plan to do this here in the next month or so!
User avatar
pontiacgp
Postby pontiacgp on Thu Feb 06, 2014 12:55 pm
are you taking the frame out or just lifting the body off of it?
User avatar
malibootay
Postby malibootay on Thu Feb 06, 2014 2:03 pm
Well I was wanting to remove the body so I could either clean the frame and paint/por 15 it or have it powder coated. But I dont have a lift. Looking for the easiest way without a lift.thanks
User avatar
Longroof79
Postby Longroof79 on Thu Feb 06, 2014 2:46 pm
After removing your front fenders, hood, and rad support assembly...and I assume your engine and trans.
After unbolting the body, unhooking parking brake, steering column, linkage, etc.
Using a few floor jacks or construction type bottle jacks, you can gradually lift the body each side at a time. You'll need a few 4 x 4's across the underside of the body to support it when you're able to lift the body high enough off the frame.
Here's Doober's build thread. It might give you a few ideas of how to proceed . http://www.maliburacing.com/forum/viewt ... 4&t=113227
Make sure you soak all the body bolts with PB Blaster or a comparable penetrating oil. Everyday, or every other day, shoot penetrating oil between the bolts and body prior to breaking them loose. You can also try loosening them gradually with a breaker bar. Be patient and you might be able to loosen them all without snapping them. I was lucky in that respect.
Jack
'79 Malibu wagon, mild 355 sbc, TH350 trans, 8.5 GN rear
Future upgrades: built 200-4R trans and 3.42 gears
User avatar
malibootay
Postby malibootay on Thu Feb 06, 2014 5:17 pm
Great info and link! Gonna study up on this for a while.... Is there certain things I shouldn't do, like taking the doors off, etc
User avatar
Doug213xrj
Postby Doug213xrj on Thu Feb 06, 2014 7:51 pm
Sent you a PM.
Doug
User avatar
lilbowtie
G Body Guru
Postby lilbowtie on Thu Feb 06, 2014 8:11 pm
If you are going to take it apart, take the front clip off in one piece. Before you pull the doors drill two 1/8 in holes in the hinge to body to re-align them when you go back together. Here is an idea for lifting the body off using the seat belt bolt holes.
User avatar
malibootay
Postby malibootay on Thu Feb 06, 2014 8:36 pm
Great info doug, thanks....did you have to remove your motor?
User avatar
malibootay
Postby malibootay on Thu Feb 06, 2014 8:37 pm
Lilbowtie, that is an awesome idea!
Next
Return to Chassis / Drivetrain / Suspension / Wheels
Who is online
Users browsing this forum: UMI Sales
