Help...working on a 1981 GMC Cabellero. Passenger side power window inop (drivers side has a mis-match door with manual window)
Took my meter, hooked ground to body, and probed the connector to the motor. I had 12v using the switch going both up and down. So I figured it had to be the motor.
Replaced motor and it still doesn't work.
Should have realized I was using a different ground than what was being supplied to the motor.
I can use a jumper and put a good body ground to the switch, hit it, and the motor works.
So, I have a bad ground going to the motor.
My question is, where is this ground coming from? I found wiring diagrams for this car, but nothing showed the power window system.
Could it be a bad switch? Keep in mind using a separate ground, the 12+ switches on and off just fine, but using the ground at the plug at the motor, it does not.
Anyone have a wiring diagram for this car that shows the power windows? Or has someone come across the same problem? Is there some sort of relay or something under the dash that switch runs through?
2nd unrelated question......are the wiper arms on this car interchangeable from left to right? I need a replacement on the passenger side, but I can only find a part number for a driver's side.
