has anyone else heard about this?
MD13ailey
337
34
Columbia city, Oregob
I wokr at carquest and its pretty boring sometimes but out EPWI rep came in the other day and started talking the engine oil standards changing again in 2011. I'm aware of what happened with the "revision" of oil hence why we have to use break in oil now. so according to him this "new oil" is a flat tappet cam killer, even if its broke in already. and he also said that you cant really fix this "new oil" by outting additives in it because of how much detergent is in it. so i thought it over for a few days and desided to get on Joe Gibbs wedsite and here is what I found;
Motor Oil Standards Set To Change in 2011
API SN/GF-5 Press Release
Contact: Lake Speed, Jr (704) 239-4401
API approves GF-5, SN to go into effect in 2010. GM Announces dexos 1 global engine oil specification for 2011 model year vehicles.
API SN – ILSAC GF-5 licensed oil will hit the shelves in October of 2010, and this new oil specification places greater emphasis on protecting catalytic converters than previous oil standards. While this is good news for emissions, improved catalytic converter life has proven to be detrimental to flat-tappet camshaft life.
Both the new API SN and GM dexos oil standards will require the use of a new type of “Phosphorus Retention” ZDP. ZDP or Zinc, as it is known, provides protection for engine components by creating a phosphate film. The creation of this phosphate film also results in a reduction of performance in Three Way Catalytic Converters. The new “Phosphorus Retention” ZDP is less reactive, so it is less detrimental to catalytic converter performance. It is unknown how this new “Phosphorus Retention” ZDP will perform in flat-tappet and high performance engines.
Another change associated with API SN/ILSAC GF-5 oils will be greater fuel economy performance. This improvement in fuel economy will be achieved by increased use of polymers called Viscosity Modifiers. These polymers help a “thin” oil act “thicker” under low stress conditions. While the liberal use of polymers helps improve fuel economy in modern passenger car engines, older style push-rod and race engines produce greater shear stresses that can “tear” these polymers. When these polymers are sheared, oil losses viscosity, and that can lead to increased wear.
More than ever before, hot rodders, engine builders, and racers need to be aware that API rated products are “compromised” due to Passenger Car OEM requirements for improved catalytic converter life, fuel economy, and engine cleanliness.
To achieve these goals, oil marketers must reduce the Phosphorus, Sulfur and Zinc levels in their oils, and they must use more polymers and aggressive detergents. While these changes are good for modern low rpm, overhead cam engines, older push rod engines and high RPM race engines need lubricants with higher levels of Phosphorus, Sulfur and Zinc as well as lower levels of polymers and detergents.
Fortunately, Engine Builders, Racers and Hot Rodders have Joe Gibbs Driven oils available to them for Engine Break-In, Racing and Hot Rodding, so you don’t need to worry. Joe Gibbs Driven oils use the “old school” ZDP for outstanding flat-tappet camshaft protection. Joe Gibbs Racing uses the Joe Gibbs Driven oils for break-in and racing our flat-tappet engines, and our engines see over 9,000 RPM, make over 850 hp and have to run more than 600 miles per race weekend. Joe Gibbs Driven Racing Oils have protected our engines for the last 10 years, and we’ve won 5 NASCAR championships during that time using these oils.
These oils cost a little more per quart than premium passenger car and diesel oils, but they provide greater value and protection. The small investment in the right oil for your flat-tappet cam will same you big money in the long run.
This doesnt look good for us I'm just glad goin with a roller cam over the winter so I dont have to deal with this crap. my EPWI rep also mentioned that it didnt look like it would effect overhead cam engines or roller cam engines. but in a performance application it would be a wise decision to use the better oil. but the bad thing is there is no definate cut off (OB1,OB2 ex) so it may screw over a lot of unknowing people I"m using the valvoline race oil the non street legal stuff part number VV851 its 20-50.
Crap, now I gotta stockpile oil too.
you can also use oils ment for diesel engines, ie. dellco 15-40, etc. etc. etc.. have used it for years with no troubles or sludge (as long as you change it on a regular basis).
Mot anymore, they had to reformulate too.
...this new oil specification places greater emphasis on protecting catalytic converters than previous oil standards. While this is good news for emissions, improved catalytic converter life has proven to be detrimental to flat-tappet camshaft life.
Maybe I'm missing something important, but would someone prove to me that catalytic converter life has anything whatsoever to do with flat-tappet camshaft life? Show me the science, because as far as I know, the cam could care less what is on the end (or the middle) of the exhaust pipe.
I might as well say that using a certain brand of wax on my paint is harmful to the life of my tires. This smells like marketing for Joe Gibbs oil because Joe Gibbs oil might help Joe Gibbs' engine get Joe Gibbs' car around better and make Joe Gibbs some more money. :rofl:
Sorry about that last bit but I'm not buying it. the Fear Uncertainty and Doubt (FUD) lesson in your marketing 101 textbook folks.
It's the ZDDP that is messing up the cats. It's also the same thing that protects the cam. So by removing it to protect or increase the life of the cat, it will harm or shorten the life of the cam. Its not a direct cause but more like a cause and effect thing.
But if an engine burns no oil, how does the oil affect anything in the exhaust?
And, are all cars nowdays set up with roller cams?
No I don't think most cars have roller cams. I've never seen a direct impingment style DOHC that has rollers on the valve lifter surface thingy I forget the term for it. For example bike motors, import motors, etc. And most DOHC and SOHC engines have rocker arms that rest right on the cam lobes, I don't think I've ever seen one of those with a roller tip on the rocker. Since overhead cams seem to be the norm these days.
But I think all Ford and Chevy push rod engines use rollers now. I could be wrong though.
They all do to some extent. There will always be a small amount of oil left on the cylinder walls.
Does that mean regular oil as we'd find now is guna be hard to find or will they be side by side on the shelves? Will there be any distinction between the types or is it guna change overnight with no warning of the change? I'm so tired of all this protect the environment bullshit, go after the big companies that polute constantly. O wait, never mind, they have enough money to pay everyone off... :wtf:
