My stock starter isnt getting the job done so i replaced it with a gear reduction mini starter and added a heat shield. When i dropped the starter i saw that the factory fusible link and positive battery cable had melted. I replaced them with a new 4ga wire (battery to starter) and cut off the old fusible links and added new 14ga fusible wire. I mounted these to the top terminal on the starter solenoid.
For my ground I cut the old stock one off and ran a 4 ga wire and grounded the starter to the block, BUT i changed the mount terminal to the terminal on the starter where the starter is grounded to the solenoid by a ground strap/wire.
I went to try and crank and i have nothing, any suggestions? how many terminals on the starter are grounds? does the stock starter ground run in a series with any other grounds?
