Here's a story about my car and engine.
I bought this 1984 Buick Regal in fall of 2011. Picked it up 9 hours away from my house, and raced it the same day where I picked it up. Laid down a 13.6 @ 102 off the trailer which was the best of 3 runs. Figured I could get that down to basement 12's with a bit of tweaking. Drove it another 3-4 times to a new race track near home, and it blew a headgasket and chewed up all the bearings on the first pass. Since fall of 2011 I have since been trying to "fix" the issue, which has gotten seriously carried away into an all out engine build.
This is the story of said engine build.
The car as I bought it;
1984 Buick Regal with Cadillac 472 engine that experienced a head gasket failure. It was a 1968 472, with 10ish:1 compression, crushed peanut pistons, 76cc stock heads, MTS#15 cam, cloyes roller timing set, ARP rod bolts, and ARP head studs. Adapted Buick rockers, and beefier valve springs. Custom oil pan, 1 header, and a custom main cap "slip on" girdle. Edelbrock 2115 intake, and an Edelbrock 750cfm carb.
Luckily I had also been given a spare Cadillac 500 with the car (core) but it was a low miles untouched engine. This 500 is what is destined to take the 472's place.
Carnage pictures of the 472;
