This is my 1980 Olds Cutlass Supreme. I picked it up in the summer of 2013. I'm the 3rd owner and it's low mileage around 46,000. It's got the stock 3.8 Buick engine and is a factory non ac, split back bench seat, am radio, base model. The only non factory item on it when I bought it were the rally wheels, but it came with the original wheels and color keyed hub caps.
It's a clean survivor car, not perfect but nothing shot to hell either. I take that back the rear bumper has tape on it which I haven't peeled off but I'm not expecting it to be covering minor rust...
The factory 3.8 leaves much to be desired so it's coming out and a boring SBC in going to replace it. I wish budget and time allowed for an Olds engine but it is what it is and it's a non Olds engine replacing a factory non Olds engine so I don't feel like too much of a degenerate...
The engine is a new GM long block assembly with a healthy cam and intake added. In the future it's going to get some head work. As it is now I'm looking at roughly 300 hp. That's like 3.5x what the little 3.8 FEELS like its putting out.
Exhaust will be full length Flowtech headers with Flowtech header mufflers then the pipes exiting in front of the rear wheels. I'll cut and weld the transmission cross member as needed for the exhaust to clear.
I lucked out and the car has a TH350 with multifit bellhousing so the Chevy will bolt right up.
Due to budget constraints I'll stick with the stock torque converter for now and upgrade it when I do the rear end swap which will likely be a 9".
I went with the serpentine drive setup from a junk 89 GMC k2500 I have. It's a non ac setup with steel bracket. I figured it would look cleaner than the aluminum setup I have from a 92 Chevy k1500 that has the ac bracket built in.
The only issue is the upper radiator hose routing but I think I can solve that with a truck thermostat housing and an upper hose for a small block Olds car.
