My 85 Elco Build
richp85elco
409
Long Beach, CA
Year and Model: 1985 El Camino
Engine Specs and Modifications: In 350, out 305
Drivetrain Specs and Modifications: 200-4r, Limited slip Diff with 3.73 gear ratio
Starting this thread to sort of keep me motivated, as my engine swap kind of developed into a whole lot more work
Picked up this engine mild 350 4bolt mains a couple weeks ago from a member on ECC Kerno you can kinda see his beautiful beast in the background (modifications to come)
Started my engine swap last week when I began with this POS 305, began labeling disconnecting wiring harness and vacuum lines etc. The wiring was completely distroyed by the P.O and many of the plugs were either disconnected or melted, lots of wires were stripped. Im amazed there wasn't a fire when I use to drive it.
Front Clip and Cowl hood off and in the bed
Tragic discoverys
Damaged AC box
Example one of many damaged/ cut wires just hanging
Even CA cars are not safe, looks like something punctures the floor board and was just sealed with silicone which probably led to rust next to it
Damaged wheel wells
More to come!
Engine and trans coming out!
Mission Complete
BTW I dont have a uni brow, those of you with glasses can probably relate. When you feel your glasses failing off your face us 4 eyes tend to push them back up by the bridge of our nose. I just happened to do it with grease on my fingers LOL. Ive actually walked in public like that without a clue as to why people are staring when I go to auto zone or something
The aftermath:
Engine bay I will be cleaning and painting.
exhaust
Stupid leaking stearing box, which has cause massive amounts of caked on grease and grime
Althought it did keep steering parts protected from rust and bushings lubricated lol
Pics of exhuast system now for sale! I have headers and true dulas coming.
Bolts on to factory 305 manifolds like mine which are pictured in other post.
Straight pipe no cat (although can be added simply and cheaply), 1 flowmaster, dual tips dumps behind wheels, does not require special cross member. Very good condition, no rust, tips have good chrome they are just very dirty the cars been sitting for months. It is very loud even with that POS 305 I was running, it sets off alarms....(if your close enough..haha)
Dont know why it looks like its cut off in the middle in this pic but its not
Chrome Tip, has one on both sides
More updates mañana!
Dissasembled the Front end this weekend
My order came in Sat to rebuild steering linkage/ front end. New idler arm, inner, outer tie rods, sleeves, centerlink, upper and lower ball joints, sway bar endlinks and frame mounts. Price for generic replacement parts was less than half the price of moog, I was really tempted but I don't want to have to do this twice any time soon. And for the price this car better ride like a caddy!
Springs and shocks and control arm bushings were relatively new before I let the car sit. So they will be reused
Proms coming soon, so guess who needs money. Bro degreasing, to get parts ready for paint.
Frame, control arms, sway bars, jounce bars clean and ready for sanding and paint..
I got the frame and everything above sanded and hit them with two coats of rustoleum rusty metal primer and will get them painted within a couple days and post some pics. It looks a hell of alot better!
Fun stuff, engine goodies, felpro gaskets, arp bolts, cloyes true double roller, comps cam and lifter magnum 270h, headers and distributor should be arriving tomorrow.
man u puttin in work!!!!!
dayumm! now thats getting some damage done! keep it up and good luck with the build
I will be watchin your build good luck,I see you startin off right tearin it down and puttin new stuff on it,at least you can get your lil bro to help,mine came over sat on my couch this weekend and watched the playoffs while I was bustin my knuckles :evil: .
