The largest community of 1978-1988 General Motors G-Body cars. Chevrolet Malibu, El Camino, Monte Carlo; Oldsmobile Cutlass, 442, Hurst/Olds; Buick Regal, Century, T-Type, Grand National; Pontiac Grand Am, Grand Prix, LeMans, Bonneville; GMC Caballero
GBodyForum Supporting Vendor
Dieting A Malibu
If your favorite tools are the torch and welder, then this is your forum.
J$Money
n00b
Dieting A Malibu
Postby J$Money on Thu Aug 13, 2009 3:35 pm
i'm soon to be puttin together a 78 mailbu and i'm wondering what kinda diet i can put this girl on to help her shed some weight and still be streetable. So far i've decided to do either lexan or plexiglass front and rear windshields and rear quarter windows. fiberglass lift off hood and possibly truck, fiberglass bumper, no rear seats. 16 gal aluminum fuel cell summit/jegs racing seats to replace the two front seats, and sheet metal door panels along w/ a 6 point cage. compared to stock weight about how much do you think i'd be shaving and about what would the car weigh in on the scales w/o a driver.
User avatar
Blake442
Postby Blake442 on Thu Aug 13, 2009 5:12 pm
Do not replace your windsheild with anything other than glass...
Sheet aluminum for your interior panels will be even lighter.
'85 Oldsmobile 442--Olds 455-TH400
'83 Oldsmobile Cutlass Cruiser--Chevy 350-TH350
Past G's--'81 Regal, '84 El Camino, '79 Cutlass Supreme, '87 Cutlass Salon,
'81 Monte Carlo, '81 El Camino, '79 Malibu Wagon, '81 Century Estate Wagon
User avatar
outsider_27
Postby outsider_27 on Thu Aug 13, 2009 5:58 pm
Blake442 wrote:Do not replace your windsheild with anything other than glass...
I agree, you compromise safety using anything but safety glass. And the sheet aluminum, gutting the plastic crap, and no rear seat will save some weight.
My lug nuts have more torque than your ricer!
http://www.cardomain.com/id/outsider_27
User avatar
jrm81bu
Postby jrm81bu on Thu Aug 13, 2009 6:26 pm
Ditch the heater and ac set-up. Fiberglass bumbers on the street ain't always a good idea but its up to you.
Here's a link to MR about this.
http://www.maliburacing.com/forum/viewtopic.php?t=40043
81 Malibu
400(350 for now) 142 supercharger
700r4
3.73 posi 7.5
J$Money
n00b
Postby J$Money on Thu Aug 13, 2009 8:12 pm
what're the cons on using a lexan window. the only reason i was gonna use lexan or plexiglass is because the car doesn't curently have any windows in it other than the driver side door window
User avatar
adumb
Postby adumb on Thu Aug 13, 2009 8:51 pm
i believe the car uses the front and rear glass as structural reinforcement. front and rear lexan would prob make the car a wet noodle. could use it for the rear side windows though.
- SBC 360: Bored 60 over, Comp Cams Extreme Energy xe274, 200cc/64cc Dart Iron Eagle Heads, 1.6 Roller tip rockers, Edelbrock Performer RPM, Edelbrock 750, Flowtech Headers.
- NV3500 close ratio, going in this spring
- 7.5 Rear: GM 3.42 & GM Gov-Loc Posi.
User avatar
jrm81bu
Postby jrm81bu on Thu Aug 13, 2009 10:15 pm
J$Money wrote:what're the cons on using a lexan window. the only reason i was gonna use lexan or plexiglass is because the car doesn't curently have any windows in it other than the driver side door window
Not as safe,as if say a bird was to hit the window. And it scratches easier, at least the plexiglass does. I'm not sure but I don't think I would want to try to use wipers on it either.
81 Malibu
700r4
3.73 posi 7.5
User avatar
Coveted
Postby Coveted on Fri Aug 14, 2009 12:17 am
lexan scratches easy and yellow. I put a brand new lexan windshield in a race car, and a crew guy scratched it with a papertowel same day, no joke.
its hard to seal aswell, but for a drag car, glass is really heavy, id say lose the back windows to lexan, leave the front 2 windows functional, and leave the stock windscreen.
you can get a gbody pretty light by gutting it, and switching to aluminum racing seats.
J$Money
n00b
Postby J$Money on Fri Aug 14, 2009 12:54 am
w/ all the glass in the car, no rear seats, 2 plastic racing seats, 6point cage, etc how much is the car estimated to weigh
User avatar
Carsten
Windows
Postby Carsten on Fri Aug 14, 2009 2:15 am
I used Makrolon windows all around on my bug , front , rear and side windows. Driver side window was possible to lift up and down , no problem. Used wipers , too . No big problem , but cleaned the front window often and used wipers not that often.Some good polish work helps , too. So it works , but i think you have to replace that front window after 2 years or so. That was , what i did.
Oldsmobile Cutlass Supreme 1978
http://gbodyforum.com/photos/index-13254.html
Next
Return to Racing / Track / Heavy Mods.
Who is online
Users browsing this forum: olds307 and 403
