Alright I'm just gathering information right now, and doing some price stacking.
This 403/Th350 is bolted into a 79 trans am right now, and I've come to the point with this trans am where it's just become too much to fix this body right now. I can still go forward with it, but I'd rather jump back on track with my Monte carlo.
So, my first question is will an olds 403 bolt to the motor mounts that are in my 88 MCSS right now? it had a SBC/ 700R4 setup prior, i still have the original cross-member.
Second question, will the Th350 bolt to the MCSS original cross-member?
IF the TH350 will bolt to the original cross-member, I'll need a new driveshaft because the MCSS driveshaft was cut down to fit the 700R4.
I considered doing the work to swap rear ends, but it's too much work right now. The MCSS has the stock posi trac, and the trans am has the stock 8.5 posi trac with 2.19's.
Next question, and i don't know if anybody here can awnser this or not but this would be a deal breaker, i have this set of headers on the 403 right now
http://www.summitracing.com/parts/HOK-3901HKR/
part number : HOK-3901HKR
Will they fit this 403 in my MCSS?
I'm going to call holley and ask if those headers will fit an olds Gbody with a 403, and if they will i'll assume they'll fit in my MCSS.
Now if anybody is wondering why i'm making such a sudden switch
This trans am needs allot of work still that i didn't know about. i mean allot.
My MCSS has a spotless interior and almost perfect body, and NO RUST whatsoever, and i don't think its ever had any rust.
Second, I've got roughly 1500-2000$ worth of Savitske classic and custom suspension parts for my MCSS just sitting in boxs. I've got the stage 2 + suspension setup for the front.
Another added bonus, the trans am weights a good bit more than the MCSS, and this 403 will be running through 3.73 rear gears so it should really go go go.
