WELDER RECOMMENDATIONS
9,614
12,683
I bought my welder about 20 years ago, it's a Lincoln 175+ that runs on 220 and I have welded everything from roll bars and frames down to thin sheet metal.
One thing I looked for was infinite adjustability for heat and wire speed so I can fine tune my weld
Another thing for me and the same goes for when I bought my Miller plasma cutter was sticking with a name brand so that any parts and consumables will be available for many years to come and I luckily have yet to need any parts in the last two decades.
wskirvin
324
423
Indianapolis, In
I ended up finding a Hobart 210MVP for $600 locally. They guy a got it from is retired from a welding supply company and buys machines at auctions and online then does any repairs or updates it needs and then resells them. Plus offers a 60 day warranty and said he can get parts at cost if something was to ever go wrong with it...... so we will see how it turns out! I tried it at his place when looking at it. Welded like it should and no issues so time to get to puttin in some work learning how to properly weld!
csstrux
143
76
I have a Hobart 180 which works nice for heavier stuff, but never could get it lined out for sheetmetal. I just picked up a Lincoln 140 last November/December? Smoothest machine I have ever used, and I am also a novice welder. If you are looking for solid for the price, I am happy as h311 with this machine. Picked it up from Blains farm and fleet online and had it shipped. I think it was a good $50.00 less than any other I could find. That said, the one I was looking at at the local welder supply shop had double the amp settings. That said, the one I have has only one issue for what I need it to do... The putz holding the trigger.
denny
279
116
just bought a jegs 180. it was just above 300. 220 and comes with a stick also.
William
34
17
Hobart 140 vs Miller 140. Hobart has a better feed system. Otherwise they are very similar. Shop around and you'll pay $500 for a new Hobart 140. Both run on 110, which is way more convenient than 220. It'll come with the gun and gas regulator. Plan to get a gas cylinder and skip the flux core for best results. Then plan to buy .023 wire, a couple of .023 Hobart tips, and a welding cart. (Yes, you can make your own cart, but they are $35 at Harbor Freight and time is money.) Read up (U-Tube) on best welding techniques.
