Sealing strips?
RICKDIZZLE
293
275
Ok after what seems like forever ago, I plan to replace my B pillar chrome trim this week. I have my old thread here and understand the process...just not sure of what to use as a sealing strip on the seal to make sure it's water tight again.
Original thread for reference. P.s. it's closed thus the repost:
I just used some closed cell weatherstripping that’s used for truck camper tops on mine.
I'm having a hard time getting my head wrapped around "sealing strip on the seal".
Are you talking about the foam seal that attaches to the back of the OEM B-pillar plate and weatherstripping channel? GM plates came with it installed and used it as a moisture seal so water wouldn't work itself behind the trim or channel.
Amazon has some. Look for around 1/16" thick closed cell. The peel and stick is likely the best since you don't have to mess around with glue. Fairly cheap and you can redo the entire car!
Reactions: 7 users
Thank you!
Yeah this is what I was referring too. I apologize if I wasn't clear.
It's closed cell camper top tape. Be sure to copy the factory pattern. You may also need butry rubber in the corners. My Regal has that.
Try the 1/16" thick junk, 3/32" at most. If you get the fat stuff you'll cry.
