1981 231 V6. Which way does the rotor point for the distributor?
antgonzo
n00b
Sep 3, 2024
32
I finally got my car running the other day but I noticed some popping through the carb and rough idling. I set my timing to 15 deg BTDC and dropped in my distributor with the rotor pointing the opposite direction of cylinder 1. Is this correct? I only did this because the diagram I followed in the book as pictured below:
I havent removed the distributor yet to point it at the #1 cylinder, wanted to get more info before I do. Also it seems that when my 4 wire computer harness to my distributor is connected, my engine runs less rough.
With the #1 cylinder at TDC of the compression stroke, the rotor should point to the #1 spark plug tower. Even though you set the crank “at” TDC, it could be the TDC of the #1 exhaust stroke, in which case the #4 cylinder would be at TDC of its compression stroke, and the rotor should be pointing to the #4 spark plug tower.
