And now, lemme tell you something you may not know...you might, but then again, it's something not many people ever bother to do.
The factory has 3 ports in the A/C system for 85-88 Cutlass with Schrader valves in them. Two on the accumulator (low side) and one on the muffler (high side).
The beauty of one of the ports on the back side of the accumulator is that its used for the pressure control switch to kick the compressor on/off based on low side pressure. The other port is for normal charging of the R-12 refrigerant. The high side port on the muffler is not normally used for service, but only for pressure gage monitoring during operation.
The good thing is that all the Schrader valves in the system are the same. They're nothing special really, just like a tire valve stem valve innards. However, they're made specifically for the A/C systems.
G-bodies use ACDelco 15-1119 (GM# 3041827) as the Schrader cores. The Schrader p/n is 8080580047. GM is REALLY proud of these little valves, typically list price is around 14 and change!! Highway robbery. They're just re-packaged Schrader valves.
Now, the hard part. These jokers LOVE to corrode in place. Aluminum pieces with rubber seals and such, makes it tough as the cores love to "weld" themselves into place. Especially the high side ones on the mufflers.
So when I went to remove the valves on the 1987 OEM hose set, I was met with almost instant resistance. Yeah, there's a plastic cap with an o-ring seal on them keeping junk out, but for whatever reason, they were STUBBORN to remove, even with a good tire core tool. I sprayed some brake cleaner in the core hole, then used the wife's toothbrush...ok, an OLD toothbrush, to scrub out most of the gunk. Then I put a couple drops of mineral oil in there and started working the valve core back and forth. I worked it loose and started to remove it and noticed the valve stem wasn't moving, so the head came up to meet the top of the center stem. WTF?
Turns out, the core was F'd up at this point. I couldn't see it, but what happened was the core was stuck at the seal, and the base wasn't coming out. The threaded core did. So it simply separated the threaded head from the base. Broken valve. So I used a pair of needle nose pliers and pulled up on it, hoping the valve at the bottom wouldn't come off and drop into the muffler. Pop. Out came the head, spring and center pin. Fugg. The valve poppet at the bottom of the center pin popped off and fell into the muffler.
Now the fun part. These jokers are SUPER small, like 0.21" in diameter. So not much is going to get to it. I don't have any easy-outs that small. Klein tools makes a special easy out for this very thing, on a double tip valve core removal/install tool on one end, flip it around for the easy out. Comes with the 11 in 1 tool. For $20. I went to the garage and found a flat top philips head screw that would fit into the hole. Gave it about a half turn to get some "bite" into the husk sitting in the hole, and then used the needle nose pliers to pull the screw and husk out of the hole. SUCCESS! It was in there tight!
Don't know what's in the muffler but it's apparently got some baffle system in it because the loose poppet wouldn't make its way through the muffler to the discharge line. Now, I wouldn't normally give a crap, but I'm taking these to an A/C repair shop to get the rubber hoses replaced, so I don't need any foreign object floating around in the system should I use the hose. For around $80 I can have 2 restored OEM A/C assemblies. Just one of those aftermarket deals is close to $100. Anyway, had to get that poppet out. Shaking it around was sorta funny to watch I guess, but about 3 minutes later I got it to come out the compressor discharge hole in the fitting.
The 1985 high side valve core was no picnic either. It did the SAME thing. This time, I was ready. But this time the head came off the center pin when the threaded head came out and now the valve was just missing a head. So I pulled and pulled and couldn't get a great bite on the center pin to try and get it loose from the poppet. The spring got messed up and wasn't very springy, so I took a small drill bit blunt in and pressed it down hoping to pop it off inside maybe. It went down and stuck. Nothing popped off. Good. I took the screw from before, turned it in a 1/2 turn roughly, and pulled out the entire valve assembly. Didn't have to fish for any broken parts.
So now, it's waiting for my new Schrader valves to arrive, along with the special 13/64" - 36 tap. The threads aren't goobered up too bad, as I had an old accumulator I stole a "good" valve core out of and it went right into both mufflers without jamming. Going to run the tap through the threads anyway, just to make sure. Then flush them out and get them ready for the new hoses.
Again, nobody thinks about these things, but these little valves can make you crazy when they don't want to come out easy.
