Power Brake Booster
Ernest
987
1,539
Texas
When it comes time to replace it with an original style or upgraded type that works along with the master cylinder... wheres a good source to find one, brand new if possible.
Spec - 1979 malibu, SBC v8 with original disk/drum setup, zero mods.
Reactions: xylorex and Rktpwrd
Nice to hear... i dont need anything fancy, just as long as it works.
For a reasonable price, it cant be beat for brand new.... did you have any trouble installing it, any modifications or tweaks?
Only hiccup was that in the course of installing it, I found that a prior owner had changed the master/booster to an '82 or later version, which required replacing the master with the year-correct unit. Would buy again if needed for the wagon.
Other than that... just a direct bolt in.
Both the master cylinder and brake booster i plan on buying are period correct for my '79 .... so i too shouldnt have any problems.
