Diagnose: Unknown Issue
Pharozen
207
59
Triana
I just had a CVF serpentine belt installed on my small block olds 350. Everything works fine BUT…when I put it in REVERSE the power steering line always pop off and I lose power steering fluid and the ability to steer and control the vehicle. If you look closely at the attached pics, you can see where the line has completely blown off (TWICE). No one seems to know the cause so I’m going to ask the masses for help diagnosing this issue. Please advise:
If you are blowing the hose right out of the AN hose end fitting then I would say you are exceeding the pressure limit for that set up.
I assembled every AN hose on both my Gbodys, except for the high pressure side of my power steering pump which I had a hydraulic hose shop make for me to avoid any issues.
How close is that pulley to the gear box? I had similar setup in 87 El Camino, had to go with smaller gear.
Also size of lines ? They looks the same, usually you want the return line one step up in size from the pressure line.
Also, who made the AN fittings? Were they Earl's or Areoquip, or other higher quality units? Too much Chinese stuff ... It's ok but not same quality, I've had issues with threads and not being able to get proper torque, before threads pop or skip.
You can mix and match fittings, but hose ends must be made by the same manufacture as the hose. If it was purchased on eBay, good luck. As for coming off when you put it in reverse, check your engine mounts. Even with good mounts, there needs to be a decent sized loop in the hose. Maybe try a 45* or a 90* fitting at the pump.
