CUTLASS Help need a Pitman Arm
old80cs
771
2,691
Massachusetts
I bought a new power steering box from Rock Auto, USA Standard Gear , ZSG7560 with 26 spline input and 32 spline out.
This box has the 4 bolt cover over the sector shaft, my original box has the snap ring cover over the sector shaft and I wanted to upgrade to the box with more adjustability going forward. Problem is my original pitman arm (#7828463) will not fit the new box output shaft. Too small by about an 1/8”. Could anybody help me find a part number for the pitman arm I need? I want to keep the steering all OEM for ease of sourcing replacement parts. The input spline count fits my new rag joint just fine. Any help finding the right pitman arm would be appreciated!
These are my original parts:
Here is the thread I got that number from, you ok’d it then too. 🙂
Thanks to Longroof79 as well for crossing the numbers!
No luck finding a GM arm but found a thread on GBF that subs an aftermarket arm from Allstar Performance- ALL56357.​
Thanks again! 👍
That's the one I bought to go with a Jeep box but it's still on the floor.
The snap ring box uses the smaller hole arm that is the same as the manual box. When my snap ring box leaked I just swapped in a manual box because it took me forever to find the 4-bolt box arm. I eventually took the 4-bolt arm off a Regal in a junkyard. Good thing too, as the manual box was a bear to park with.
I bought the Allstar pitman arm at the same time as my Borgeson steering gearbox and it has worked perfectly in my Regal for years now.
