Help identifying ball joint
LightningMike
9
36
13
50
My car had some aftermarket suspension parts installed before I bought it. I need to replace my upper ball joints, but I have no idea what brand the A-arms or Ball joints are. I'm hoping someone else has the same brand and recognizes these. The ball joints are screw in, which I've never encountered before.
arms that look like that with screw in versions are usually a circle track based part.look into Howe ball joints.i'd start over on speedwaymotors.com
Those A-arms look like the ones that Robert Adams used to sell back in the day. I don't think he sells the kit anymore since all the links I've found are dead. Just to add to the confusion or to prevent you from falling to some gotchas...chances are with those A-arms, you have A/B-body spindles or possibly F-body spindles which means the rotor diameter could be 12" or 11" depending on which spindle you have. The Chrysler screw in ball joint does have a different taper to them so the GM spindle is reamed to accept so if someone decided to change out those UB machine arms to say GW or Hotchkis that upper balljoint taper would need to be addressed. Calipers, brake pads, bearings...all the replacement wear parts would be specific to the A/B/F-body vehicle and not the G-body. Ahhh that’s not entirely true 12” third gen f-body 1LE rotor for the 4 3/4” bolt circle…
Glad JeffD still hosts this page.
Robert Adam's Kit on an SDime
Those A-arms look like the one's that Robert Adams used to sell back in the day. I don't think he sells the kit anymore since all the links I've found are dead. Just to add to the confusion or to prevent you from falling to some gotchas...chances are with those A-arms, you have A/B-body spindles or possibly F-body spindles which means the rotor diameter could be 12" or 11" depending which spindle you have. The Chrysler screw in ball joint does have a different taper to them so the GM spindle is reamed to accept so if someone decided to change out those UB machine arms to say GW or Hotchkis that upper balljoint taper would need to be addressed. Calipers, brake pads, bearings...all the replacement wear parts would be specific to the A/B/F-body vehicle and not the G-body.
Yeah, those look like an exact match to my A-arms. Thank you so much for all that information.
I just got the K772 in, and the old ball joint appears to be about 1/2" longer in total length. Is it okay to run it?
There's nothing wrong with a longer ball joint per se as long as the taper allows it bottom out and the body of it isn't hitting the spindle.ive never seen one with a limiter like that before.is it a washer that's pressed on or is it machined?
Reactions: LightningMike
You should be able to use it. I've never seen that washer stop either though. If you picked up a set so both match and like melloelky stated the taper lines up you should be ok. Camber may change a little but unless it was set up to take corners at speed with the old set up id send it.
