CUTLASS Power Brake Booster Check Valve?
RICKDIZZLE
Isaiah 41:10
554
983
Friends, through the course of working on my steering today...a poorly placed hand snapped my super old power brake booster check valve off at the hose. Will be picking up another one, no issue. I did notice when I pulled the old check valve, I could hear air being sucked in.
Should I bleed the brakes once the new one goes on? My thought is I should be OK as I didn't open anything or mess with the lines, and the system should go back under vacuum. Am I correct in this thought process?
