Alright guys, so after much much reading and adding costs up and seeing which route would be easiest, I've decided to go with the 5.7 Tpi as my base. Another reason I chose the Tpi route is because I can buy a complete late 80's Iroc for around $600-$700 with stock wheels🙂 which I also like. I'll be able to pretty much have everything I need to have the car refereed here in Cali. Now I have noticed that the aftermarket intake mani's don't have a spot for egr, so I'm going to look into getting a ported stock intake mani. I've never built an engine before, nor do I know the EXACT specs i'll need, so that's why i'll need your guys help. There is a local, reputable machine shop that will be doing the work for me, whatever I feel like I can't do. (mainly the bottom end work and porting and polishing the heads.) Enough with my ranting and on to the build. But first, check this out, and if any of you know this guy, or are this guy, what the heck does that Monte have, lol very impressive. http://www.youtube.com/watch?v=zfjkIZOzMOw
Engine-5.7 Tpi bored over to 355 with about 10.5 compression
Intake mani-Stock, ported
Heads-Not sure whether to go Corvette aluminum tpi with 202 valves or just regular tpi heads with 202 valves and either will have port and polish.
Cam-Not sure but needs to be street friendly. (Don't want it sound like a dragster)
Headers-Hedman Longtubes?
Exhaust-X-pipe with true duals(just not sure the oiping size since it'll be dual)
Ecu and tuning-Manley Performance here in Socal
Injectors/fuel system-Not sure what all i'd need to upgrade or add.
Trans-Would love to go manual but might have to stay auto, depends on what deals I come across, so ideas for both please.
Drive shaft-Stock or are the lightweight ones worth the extra dough?
Rear end-Monte SS with Posi and 342 gears? Want to get AT LEAST 20 mpg hwy.
Tires-Suggestions?
Tires-Suggestions?
