Have a 84 monte with a 350 putting out about 325 horse power with a 750 Holly built for this motor, Edelbrock intake and mild Comp cam.350 transmission/w 2500 stall and Rear end is a 8.5 10 bolt 3.42 gear out of a 1986 Grand National.This combo get me in the 13s?
325 rear wheel horsepower or is that at the crank? If it is at the crank I would say probably not. If it's at the wheels you should be able to dip your toes into the 13's.
If there are no traction issues ... I would say a high 13 second ET if you have a 325hp motor, low 13 second ET if you have 325hp at the rear wheels 8)
do you know which cam? can you give cam specs? Some info on heads? which Edelbrock intake?
... traction is everything. On tires, my car struggles for 14s, slicks is a different story.
sounds like you have a similar build as mine, but I think you have a better match stall and you will see good consistent results from that.
