For maximum straight line traction on the street I planned on useing 295/65/15 drag radials (29" tall) on 15x8s. But I prefer 8.5s. This requires the frame notch but allows for the wheel to tuck up into the wheelwell. For a slightly smaller footprint/less traction I have seen a 325/50 on a 15x10 but it would not fit in the wheelwell without wheelwell modification as well as a frame notch.
a 325/50 on a ten inch rim will fit without a frame notch you will need to modify the wheel lip to keep from rubbing oh and I run 15x10 AR bajas with a 3 5/8 backspace with a 325/50/15 bfg dragradial
