Here is some pics of a 17x9.5" Corvette Sawblade Wheel with a 275/40/17 Goodyear EAGLE F1 ASYMMETRIC at
stock ride height on my 1980 El Camino. I am running a 2.75" thick, bolt on wheel adapter. The wheel itself has a 56mm offset or a total of 7.45" of backspace. Adding the 2.75" bolt on adapter, the total backspace come to 4.7" of backspace.
The only front suspension change is an addition of the speedway tubular upper A-arms with stock ball joint length.
On the front, with the suspension at full suspension droop, the driver side tire comes into contact with the brake line bracket when the steering is at full left turn lock. I don't expect to get full suspension droop anytime while I am driving, especially when taking a turn at full lock. At ride height at full left lock with all the weight on the suspension, there was no interference, as far as I could tell, on the rear of the suspension, frame, fender well, or brake line bracket.
At ride height with full weight of the car on the suspension, I did have to trim the front lower corner of the fender opening when turning the wheel to full right lock as it came close to touching. At full right turn lock, I do not remember getting any interference at full lock on the front of the suspension, frame, or A-arm. With the suspension in full droop, I do not remember getting any interference at full right turn lock on the driver side tire and wheel. I haven't drove this yet, so other tire rub may happen that I could not see.
I am only guessing here, but if you are using a drop spindle, you will gain some clearance at full droop between the brake line bracket or upper a-arms, but the tie rod will get closer to the wheel and your tire will move up and closer to the fender well.
With this wheel, tire, and 2.75" thick adapter on the rear, the tire fits perfect with stock 1980 springs and suspension pieces. There is finger distance between the frame and this tire and more than finger width between the tire and the fender lip (sorry no pictures).
