1964 gmc c10 short bed with step side
Emmanuel cuellar
732
253
33
If I can remember right, you should have a purple 14 or 12 gauge wire that will go to the S terminal on the solenoid & if your using a points distributor a yellow resistor 16 gauge wire that goes from the coil to the R terminal on the solenoid. The points coil power wire should be a red 16 gauge wire. Going with HEI you'll need a 14 gauge wire for power tied into the ignition fuse.
Can u gibe me a call some time tommoroe 8322060129 thank u so kuch for ur time n effort every good action never goes unseen thank u brother gibe me a call thanks
Where does pink wire from distrubeter go
