1985 el camino
No can do. They do not interchange and the body lines do not line up.
You would have to use the doors and fenders and hood, also and if I recall correctly the fenders are longer the the El camino / Malibu fenders so the core support will not bolt up to the frame with out mods.
Jeff
The easy solution is the El Camino SS front end used on the Choo Choo customs conversions back in the day. They are reproduced, but I forget who does it...maybe Lauren Engineering?
el camino
if you put the whole front clip from monte ss on el camino you have to use the doors also but you have to use el camino door glass in them then it all works....done it
