Longroof79 said:Any model 200-4R can be upgraded with better governor, valve body mods, performance servo, and other goodies, etc. Granted the desirable cores are the ones mentioned. BRF, CZF, OZ etc.
V8 Rumble said:2004R is the correct name for this trans.
Actually the name was officially changed to THM200-4R within it's last couple of years in service because of improvements. (The later years being better than the early years. About '87 to '90.) When this trans first came out in '80, it was called THM 200R4 just like the trans named after it, the THM 700R4 two years later. (Even though the 700R4 had more improvements, it never got a name change until '92 to 4L60.)
Most still call it the 200R4 and technically they are not incorrect. Knowing the exact years by glance is nearly impossible without the knowing the serial numbers. The letter codes don't accurately tell the years. Personally, It's confusing for me to call it 2004R when I still mess with 700R4s.
Just thought I'd clear that up a little.
T
