I have 3 for sale. More hen's teeth. Takes place of the front RH side marker lamps from 81-86 models. Since the 87-88 G47 had cornering lamps by the headlights, they no longer needed to be a lamp for the side markers, so they simply didn't form the hole for the bulb holder and they became "reflectors". But the boss is still there. GM p/n 5974040
Sorry, only RH versions. I have no LH versions.
$45 each shipped from zip 29803. Check or money order.
Below is what makes these different. No lamp socket provision.
Note the DOT "date" is 1981. The same lens was used through the entire A/G47 run.
