36mm front bar
they are just using the metric measurement, its somewhere around 1 1/4" diameter.
(not too shabby eh, i live in canada and dont know what the conversion is for it. lol)
and as for omegaman211's question, you may have to just trim your stock bushing to the diameter you need. or buy the bigger bushings and bushing brackets. i am pretty sure the 1LE camaros had a sway bar around that size.
Its not an aftermarket bar its the 36mm hollow bar from a 91 1LE Camaro. I'm trying to find out if there is a 36mm bushing that will fit my 32mm bracket. Kirban lists a 36mm bushing but they said it wont fit into an A/G body sway bar bushing bracket.
the 1LE bracket should bolt right onto your car without any problems.
you shouldnt have to modify or get any special bushing.
You are referring to the 3rd Generation Camaro 36mm Lightweight Hollow front sway bar yes?
The GM part number for the bushing is 14094344
On a GN that bushing fits the stock GN bracket but the Camaro bracket does not fit the car. I assume that bracket won't fit any G-body but don't quote me.
The f-body bracket will not work had to use the stock g body one.Holes on the f body one are offset
That is what I thought I remembered.
Did you get bushings or did the ones on the bar fit?
Have you had the car out since putting the new bar on?
Used the bushing that came with the bar for now still have to install one end link(ones from the firebird)ran out of time before I had to to work hope to finish tomorrow should make a difference compared to the old bar,next step is new springs s10 ones for the front and monza for rears
