4l60 700r4 help please!!!
84monsterSS
31
48
rutledge tn
tearing into the 700r4, and not sure what its called, but where the tv cable comes into the trans, the lever that connects to the tv cable, was opened all the way, and rod was stickin g out in pics, when i twisted it back, it feels really tight.....................
could this be the problem?
got to where all it had was 1st gear, and reverse, no 2nd 3rd, or o/d
check out the pics and let me know asap please,
thanks guys,
david
as u see in bottom pic, the lever was stuck open,and rod was all way out like in pic, like its bent, its real tight and cant get no spring action, could this be the probles?
thanks again guys
What year is your trans? I know when they tore into my 700r4 over spring break, they had showed me that the sunshell had flexed outward and left groove marks in the inside of the housing. That could be a possibility as well if your not running the beast sunshell.
What your looking at could probably be another major issue as far as fluid travel and pressure. Sounds like its time to take it to a trans shop and have them look at it.
its a 1991 out of fullsize conversion van original........
it was supposed to be built with the beast, and corvette servo......, let me know if u can tell be pics.....
84monsterSS said:
got it tore down and looks like the band went bad, what cause this?
heres pics of what damage it did to shell.........
no metal, just sludge, im guessing from the band.....
vb lookin good
clutches and steels look good......
the band................
everything else looks good in there, what caused this to happen?
2nd question is...........
wheres best place to get these parts, id prefer B&M......
any help please guys, and thanks alot
david
bump....................
any help please............
Check in the bore where that rod goes, make sure no scores. Then I would throw a level on that rod to see if it is in fact bent. If that is the case and it is bent, that would give you those problems.
There's a lot of updates that should be done. Otherwise if you go cheap you will be pulling again. 3-4 Clutches like to burn up. Do a search to get all the updates to your trans.. Use the number on the trans to find out the updates..
what #?
In that last pic you posted, that is the sunshell. I need to see the neck of it to tell you if it is a beast sunshell, as the neck on the beast is reinforce welded around the neck. That sunshell looks pretty scorched and what all is in the bottom of your oil pan? Looks like shavings but that could just be me.
Heres a list of some of the updates from GM:
08-07-30-027 06/04/2008 A/T - No Movement in Drive or 3rd Gear
99-07-30-021 10/01/1999 A/T - New Solenoid Testing Kit
87-71-74 11/01/1998 A/T - 1-2 Accumulator Piston/Outer Spring Replacement
377148A 11/01/1996 A/T - Shift Solenoid Update
ATRATB334 01/01/1996 A/T - Delayed Forward Engagement/Burnt 3-4 Clutches
ATRATB256A 01/01/1996 A/T - 4L60/700R4 Rear Planet Failure/Lack Of Lube
577103 02/01/1995 A/T - Leak at Rear Extension Housing
ATRATB292 01/01/1995 A/T - 700R4 No 2nd, No 4th and No TCC
467108 12/01/1994 A/T - Extension Seal Leaks
377110 09/01/1994 A/T - Torque Converter Clutch Shutter
477109A 05/01/1994 A/T - Holley Variable Pressure Control Solenoid
477107 05/01/1994 A/T - New Center Support Bolt Service Package
377131 03/01/1994 A/T - Loss of Drive in All Ranges
ATRATB265 01/01/1994 A/T - 700R4 Rear Planet Failure/Lack of Lube
ATRATB257 01/01/1994 A/T - 700R4 Missing Reverse Checkball
ATRATB234 01/01/1994 A/T - 700R4 Forward Sprag Design
460601 01/01/1994 Warranty - Extended A/T Warranty Coverage
ATRATB201 12/01/1993 A/T - 700R4, 2004R No Line Pressure Rise
ATRATB196 12/01/1993 A/T - 700R4 Shifts In Manual Low
377129 11/01/1993 A/T - Fluid Leaks Through Connector
ATRATB179 07/01/1993 A/T - THM Late or No Upshifts
ATRATB175 07/01/1993 A/T - 200/200C/200R4, 325/3254L, 700-R4 No 2nd Gear
367102R 07/01/1993 A/T - Cooler Replacement/Flushing
932287A 06/01/1993 A/T - Click or Whine in Third or Fourth Gear
923477A 05/01/1993 Warranty - A/T Service Procedure Policy Changes
93114A7A 03/01/1993 Torque Converter - Squeak Noise
931437A 03/01/1993 A/T - Revised 3-4 Clutch
931477A 03/01/1993 A/T - No Upshift/Stuck In First/No Codes/Exterior Leaks
ATRATB134 11/01/1992 A/T - 700R4 Bind In Reverse After Rebuild
93297A 10/01/1992 A/T - Buzzing Noise at Idle
922477A 08/01/1992 A/T - Precautions on Wiring Harness
922727A 08/01/1992 A/T - New Wiring Harness With Inline Temp Sensor
ATRATB118 06/01/1992 A/T - 700R4 Valve Body Interchange
92427A 11/01/1991 A/T - Intermittent Slip, Downshift, or Busy Cycling TCC
92267A 10/01/1991 A/T - New Trans Fluid, Dexron IIE
913877A 08/01/1991 A/T - 4L80-E/4L80-EHD Grunt or Squawk Noise
913967A 08/01/1991 A/T - Evaluating Peened Spacer Plates
913907A 08/01/1991 A/T- THM 700-R4 New Output Shafts and Seal
ATRATB058 07/01/1991 A/T - Valve Body Assembly 700-R4 Inspection
913717A 07/01/1991 A/T - 4L60/700-R4 Transmissions Stuck In First
913607A 07/01/1991 A/T - Double or 1-2 Shift Shudder
913487A 06/01/1991 A/T - 4L80E/4L80EHD Buzz/Vibration
912837A 04/01/1991 A/T - 4L60 Binding/Inoperative In Reverse
ATRATB043 03/01/1991 A/T - 700R4 No 4th, Late 4th, Falls Out Of 4th
911867A 02/01/1991 A/T - New Wave Plate Now Available
911127A 11/01/1990 A/T - 4L60 Steel 3-4 Clutch Plate Availabi
ATRATB024 09/01/1990 A/T - Harsh Reverse Engagements
ATRATB8928 09/01/1989 A/T - 4L60/THM 700R4 200R4 Fluid Filter Seal
ATRASIL8733 10/01/1987 A/T - 700R4 New Auxiliary Accumulator Valve Body
ATRATB8754 09/01/1987 A/T - Front Bushing Wear
ATRATB8748 08/01/1987 A/T - Slipping or No-Shift/Metal Sealing Rings
ATRATB8744 07/01/1987 A/T - 700R4 Low And Reverse Clutch Failure
ATRASIL8627 11/01/1986 A/T - 2004R/700R4 Oil Pump & Slide Service
ATRATB8623 05/01/1986 A/T - 125, 200C/200 4R, 700 R4 Hidden Residue Build Up
ATRATB8612 03/01/1986 A/T - Converter Clutch Shudder
ATRATB861 01/01/1986 A/T - Rapid Converter Pump Bushing Wear
ATRATB8524 01/01/1985 A/T - No Converter Clutch Apply When Unit Is Hot
ATRASIL8521 01/01/1985 A/T - 700R4 Valve Body Modification
