7.5 help
1slo86elky
39
35
Culpeper Virginia
im in the process of of getting a 7.5 rear ready for my elcamino and wanted some opinoins. Plans are to put a mini spool and c-clip eliminators in it. what is a good brand of mini spool i was thinkin richmond. also does anyone know who makes a c-clip eliminator kit for a 7.5 with stock axles??. and one more question where can i get a new or used 3 series carrier? mine had the bolt broke off that holds the cross pin in. ive looked on the NAPA webite and a few other but no luck.
Thanks. Josh
Thanks. Josh[/quot
mini spool i would go richmond or auburn gear. both good companies with quality products. ive used a richmond in my ford and i plan on using a auburn in my cutlass. c clip elims u can get from either strange or moser. u got to measure the seat of the axle where the bearing will press on to though to make sure u get the right ones. and u can pick up a carrier at any gear shop. ive got the 7.5 empty carrier new at a local gear shop for 70 bucks. or u can get one on ebay. since ur goin mini spool anyway and u got a bad carrier have u thought about just goin to a full spool. u might save some cash that way.
does anyone make a full spool for a 7.5? ive never seen one that is what id do i just didnt think they were available
