Other than the actual swapping of the rear ends themselves, all you'll need to do is to have your driveshaft shortened.
If you have a 200-4R, then just see if you can get the driveshaft from the 8.5 car.
...and if you can't get the driveshaft from the donor, it's 1" that you would need to cut off. A car with a 200-4R and 8.5" rear has a 51.5" driveshaft centre to centre.
