If you unbolt just the torque converter to the flexplate. Slide the torque converter all the way into front pump. Measure the gap between the flexplate mounting point and the mounting point on the torque converter. The perfect gap I was told by a few transmission places should be 1/8". Then put shims/washers in to get to that gap. One transmission place uses a kind of crude method but they take three washers stacked together, if it fits into the gap then they use 1 washer as a spacer on all three bolts. If the three washers do not fit in, then the gap is within the tolerance and you do not need spacers. I have notes on it somewhere...because my last torque converter needed a small spacer. You can call up any of the performance transmission places and they can verify the gap that should be there. This is just to make sure that the torque converter is not too deep into the front pump or is not too far out. There is a pretty decent amount of wiggle room there I am told so it is not usually an issue. I was a little afraid to put the spacer because as you space the converter out it also sits less in the end of the crankshaft hub. Hope this helps you out.
