700r4
carlitothemac
33
6
brooklyn
www.cardomain.com
:roll: ok im hoping someone here has good knowledge of these transmission
it shift ok i think i adjusted the tv cable fine now. but its not going into overdrive why you think this could be. this has nothing to do with the servo I've changed right. actually it shifts pretty strong to but at highway speeds it stays at 3rd and of course when you step on it it wont shift down for more gitty up.is there anything i can do to remedy this.bcuz its very annoying. anyone pls thanx.
lock up harness
ok does anyone think those lock up harness from tci will work for the 700r4. no overdrive and it wont kick back down for more power.but i'm wondering if this will work even though i have a non lock up converter.
the lockup solenoid does lockup only. plus, lockup only occurs once you're in 4th gear. stupid question:which servo did you replace?
just did a little google research found a few seperate sites talking about the 700r4 not going to 4th. they said to check the governor--that the plastic gear strips. you can try calling bowtie overdrives and tci and ask them.
ohhhhh well
