hey, welcome
on my GP, I am running 16" IROC-Z wheels. They are 8" wide, with different backspacing (BS) front to rear.
Front: 4.75" BS
Rear: 5.25" BS
To avoid shearing/breaking studs, I opted to use "Front" wheels in rear, and "Rear" wheels in front. I added a 1" adaptor infront, so that it would not hit the tie-rod. In the rear, I used a 3/8" spacer just to be safe.
(to avoid this ofcourse... you can find yourself four "Front" marked wheels)
using IROC 16s on a Gbody is not really the greates setup, as it causes alot of headache. For example, to use a 3/8" spacer in rear, I had to upgrade to extended studs (2-7/8" long), which no longer worked with normal lugnuts. I had to source open-end lugnuts, which are tough to find with a deep conical seat.
I used these raised Gorilla, open-end, lugnuts:
http://www.summitracing.com/parts/GOR-90087/
For upfront, it was tough to find a decent 1" adaptor. I would avoid any cheap ones like this:
http://www.summitracing.com/parts/TRD-7070/
This adaptor is made from cast aluminum and has been known to shatter at extremes.
On my wheels, I am running 245/50R16 tires, front & rear. A tire this size gives plenty of grip and handling, and you'll find that US brands like Goodyear or BFG are wider than foreign brands, even in the same size. If I could do it again, I would find a taller tire for the rear (as 50series tires look small in the back), and a skinnier tire for the front (the 245 does rub at full lock).
I hope all this info helps,
if you have any questions, feel free to ask...
