I've got a 79' Olds Cutlass that my grammy got brand new. The old 260 is tired and "gutless" so i got an LT1 to put in. I've got most of my bugs worked out and got the wiring and fuel system pretty much done and the engines almost ready to go in... My issue is that with the switch from olds to chevy motors I've had to swap the motor mounts to the frame. So i put in a pair of mounts for the vin code H chevy motor that was available that year and the those went in just fine.
My bump in the road is that i needed to get the motor mount brackets off the side of a chevy SB. From what i had seen and read on other threads about these swaps is all i needed was any sbc motor mount bracket set. so i got some on craigslist...
Though the motor mounts hold the engine brackets very nicely. when i bolted the brackets up to the engine and tried... tried to drop the motor in something was obviously amiss.
the motor looks like it wants to drop in but there is no doubt not going to go.
my Question?... should i be looking at getting motor mount brackets (the ones that bolt on the engine) for a G-body V-8 specific or are the frame mounts the issue? I'm under the impression the frame mounts are fine, according to my cutlass FSM. so that leaves me with the engine side of the mount.
thanks in advance for any help.
