Hello. I’m new to this forum. I’m restoring a 1984 Hurst and I am at the point of figuring out the t-top replacement metal
Does anyone know how to (attach / secure / assemble etc) the top upper finish molding which is seen when the t-tops are on and the tops slide under
I bought the 8 piece Stainless replacement kit and was told that piece gets separated in the middle on the bottom side then pushed in place then welded or rivited in place....
before I pry it apart I’m seeking help because I don’t want To ruin it if that is incorrect
