As title says, swapped a 5.7 Vortec into my 442, now it won't run... Got rid of efi & ecm, installed a cheap Chinese clone of Edelbrock's Vortec Etec spreadbore intake, and a Chinese Quadrajet, as well..
New HEI Distributor, (Accel performance), adding Accel HEI Supercoil, and performance module... China struck twice more, with a Vortec mini starter, and a chrome one wire 140amp Alternator, bought a standard rebuild kit to return it to 3 wire, and replace the parts that typically fail, with that particular listing, according to reviews...
Got a Carter rotary external fuel pump, (since Vortec doesn't support mechanical pump, unless you get a roller cam that includes the eccentric)...
Given all the parts thrown at it, under normal circumstances, the Vortec should have fired right up... But for reasons yet undiscovered, refuses to run... One very odd thing, timing set static, Timing mark lined up, point rotor at #1, cap #1 plug wire lined up with rotor, etc. Checked cranking with timing light, fires 90 degrees advanced...
Replaced ignition switch, hoping a contact was culprit, nope... I have checked, and/or replaced everything I could think of, that might cause this no start issue... So far, nothing has made a difference...
I had an '82 Blazer 4 bolt 350 in it, which ended up having a cracked block, discovered cracks in valley, just below deck, on both sides, when I pulled heads, prepping for vortec head swap... It ran fine, prior to that...
Anyone have a similar issue? Seems far deeper than the typical reasons for a no start condition... Thanks in advance, for any assistance given...
