80 regal turn signal
nickin520
n00b
Feb 25, 2014
Ok my question is reguarding the turn signal relay on my fuse box where the relay i suppos to go the wires and pins are missing so before i pull the fuse box does anyone know what color the 2 wires for the pins should be thanks in advance
There is no "relay" on these older cars, you only have a flasher. Simple answer is there should be a dark blue and a purple wire. The dark blue wire that goes from the turn signal fuse to the flasher and then a purple wire goes through the steering column connector to the directional switch. Hope that helps. If you would like the wiring diagram let me know.
Yeah the flasher is what i meant im hoping the wires are just pulled out if not and i find the wires can i extend them and use female spades on the flasher and if so does it matter what terminal on the flasher they go on thx
