1. I have a cam....
2. There are NO COLORS on my two HVAC vacuum lines (everybody says the lines should be purple and white, which is true.......purple for vent door and white for the heater core valve bypass)
Both of my lines are WHITE!! So, I can't tell which one is for the vent door.
I am blowing only through defrost/floor.
My driver side vacuum canister is completely unhooked now, therefore I am getting vacuum straight from my carb...using the full-time vacuum port. I am bypassing the ball on passenger side also.
Do I have to use the ball.....the vents open by vacuum, so if I have enough vacuum, the ball shouldn't matter right now?
Either i'm using the wrong vacuum line, or I don't have enough vacuum?.....
