I wanted to replace my steering box in my 83 el camino ss. The shaft is worn out and it just be easier for me to replace it with a new or slightly used one. Does anyone know what will bolt up, for example could I bolt up a quick ratio steering box from a monte carlo 85-88. Does anyone know which one interchange and what else could I use. Example i know 80-83 el camino steering box will work for an 83. If not can anyone recommened a replacement for my 83 el camino steering box thats new. I want to fix the suspension so im starting at the heart of it. I already replaced the springs, shocks, upper control arm bushings. Everything else will follow example pitman arm, idler arm, tie rods and so on. Thanks for the help
