Got an 83' el co with starting issues. Batt is good. Fuses look fine. Havent checked the starter b.cause i want to rule out the ignition first. Any help is appriciated
i recommend checking the starter first before messing with the ignition..
there s not much to look for unless you know your starter is good for sure.
btw, it would help if you told us what it was doing..
