Could be many things, it could be the pump, carb, or even a clogged fuel filter and other possible things. Check your distributor rotar as well. My car would die when I accelareted hard, come to find out the rotar was burnt up.navarro said:ok . not sure but i think it my fuel pump . when i accelerate my car acts if it starving for fuel and dies. only on free way speeds .when im in town at cruising speeds its fine .please help
Evan's 85 said:Could be many things, it could be the pump, carb, or even a clogged fuel filter and other possible things. Check your distributor rotar as well. My car would die when I accelareted hard, come to find out the rotar was burnt up.navarro said:ok . not sure but i think it my fuel pump . when i accelerate my car acts if it starving for fuel and dies. only on free way speeds .when im in town at cruising speeds its fine .please help
Yes u should be able to tell if it's ok by looking at it, the metal contact will be ate up or severly corroded.Check that out 1st. U recently put a filter in? It could be the accelerator pump as 88 said also. U can check to see if the accelerator pump is ok by taking the air cleanor off and pushing the throttle back and forth(car does not need 2 be running)u should be able to hear and or see fuel being pumped in if it's ok. Also a new fuel pump is only maybe $18, if all these other things check out ok, u might as well throw one on.navarro said:Evan's 85 said:Could be many things, it could be the pump, carb, or even a clogged fuel filter and other possible things. Check your distributor rotar as well. My car would die when I accelareted hard, come to find out the rotar was burnt up.navarro said:ok . not sure but i think it my fuel pump . when i accelerate my car acts if it starving for fuel and dies. only on free way speeds .when im in town at cruising speeds its fine .please help
on the distributor did u just change rotar out. i changed fuel filter in carb.
Evan's 85 said:Well?navarro said:ok ill try in morning thanks guys
